Tom engine compartment painting
What kinda paint did you use?  Any prep or just open up the hood and paint away?
I just painted my vortec cover like his, what I did was the same as him.
Cover comes off w/ two screws.  Hit it w/ some steel wool, I put on two coats of primer, two coats of red paint, went over the raised lines and "Vortec" w/ a black testors paint pen the put on some clear coat.  I just put it on yesterday when I did my K&N, but I gotta say it looks good, if I get access to a digital camera I'll get a pic up before I leave for Vegas.
Ryan,
I did pretty much as chevy4x4 and Larry mentioned except I didn't use any steel wool (just cleaned it real well with some purple power spray cleaner).  I used some of that primer stuff for plastic and other flexible materials, then used Some Dupli-Color truck and van spray paint that I got at Advance Auto Parts.  I didn't clear coat it though.  They had the correct color for my truck, but I can't remember off hand seeing any indigo blue, if that's what your going to use.  I didn't really look for other colors though.
I used a testors paint pen like chevy4x4 mentioned also and some 1/8 inch wide pin stripping for the ribs on the top.  I also used it on the ribs on top of the air cleaner box lid.
Good luck.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
