Maybe been seen here before...
asilverblazer
For me it has it's ups and downs. I think I'd rather go with an SSR though if I were going to do the "Retro-active performance Vehicle" thing.
The Biggest drawback on the Bel-Air for me is the Interior. Too plain, I think it needs some black in it (Like the knobs and buttons for instance).
I do applaud GM for going back to the Column-shifter. Autos were meant to be shifted on the column! :cheers:
Damm Im confused! I like it and dont like it at the same time!! (styling wise) Its got all the right ideas but there is something wrong about it, something too, i dont know almost "ford" about it. But I still think that would be a popular car but to who? I really like the Vortec 3500 turbocharged in-line five-cylinder concept engine that delivers up to 315 horsepower and 315 lb.-ft. of torque"!! Deffanitly a more euro style power plant (even though 3.5L is freaking huge in england, hell so is 2.0L). But I can also see all the people saying "man I would buy it if is had a LS2 in it).
Cool but i would not buy it.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
