Virgin Mary on a Grilled Cheese
elboberino
Check out this ebay auction. Its real alright. It was stopped once but she convinced ebay it was a real auction. I got an email about it from the Palm Beach Post or something like that. As of the time when the article was written, the highest bid was $5,1000. Check it out. Clicky
I see the next Mastercard commercial now. :loser:
Bread: $2.50
Cheese: $3.25
Hospital Visit: $300
Funeral Services: $1000
Total Damnation in Eternal H*llfire cause you choked on a grilled Cheese sandwich that had an image of the Virgin Mary on it: PRICELESS!
:banghead:
Hmmm....they reset it again....the first time i replied it was at 99 million. I honestly can't believe someone would pay 69K for that, and I can't CANNOT beleive someone actually convinced ebay that it was real.
EDIT: I want to know 2 things....why is shipping 9 bucks....and if you really believe that it's Mary on there...shouldn't insurance be more than $.50?????
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
