'96 GMC C1500 305 Ext - Hard Starting
Hi Gang,
Here's my problem:
About 6 weeks ago, while on my way to work, out of the blue, the truck died on the side of the road. I had the local garage tow it in. I picked it up that night. I was told that the crankshaft position sensor had gone (no spark), but it had not thrown a code.
I took it home that night. The next morning, I had to crank the engine for ~30 seconds before it would start. When I started it again to go home (9 hours later), it started fine. Would do this consistently.
After talking to a buddy with a similar truck, he had had fuel system problems (stemming from a clogged fuel filter) which had resulted in a similar starting problems. After 2 days of this BS, I took it back to the garage and had the fuel filter changed (can't remember when I last changed it). No avail.
Sidebar: I was told by mechanic that I should change O2 sensors, could improve gas mileage.
While under the truck looking for/at O2 sensors, noticed that the CPS sensor that had been "replaced" appeared to be used! Ordered new CPS, replaced it myself, hard starting problem went away. Won't be going back to that garage!!
Fast forward to this past Monday: I had been on the road and the truck had not run in about a week. Tried to start it, had to crank for ~1 minute (in the end, had to boost it off the car). Truck started fine that afternoon. Didn't try to start the truck again until today. Wouldn't go, didn't feel like messing with jumper cables, hitched a ride with the wife.
After all of the cranking, when it does start, it catches about 1-2 cylinders at a time. Once running, it runs fine. All of this time, it has not generated any fault codes. BTW, it has about 70k miles on it
Any ideas? Anyone encounter an issue like this?
Thanks in advance,
Derek
"Sounds" like a fuel pump problem.
When you know it is going to act up again, do this. Install a fuel pressure guage on the fuel rail. Have a buddy watch the guage.
Turn the key on; but don't start it. With the key "on", fuel pressure should jump to 60psi. If anywhere under 60 psi, could be a fuel pump.
Could also be any number of things. How's your cap and rotor? How are tune-up items? Worst thing we can do is guess; just trying to give a good starting point.
Could also be a few injectors sticking open, which would cause a loss of fuel pressure.
Gonna have to diagnose this a step at a time.
Also do a search on this site under "hard start" or "fuel" Lots of info.
Hi Gang,
Here's my problem:
Thanks in advance,
Derek
Maybe a little simpler that that, check your battery. without full voltage the coil will not fully fire the plugs until the engine turns enough to generate voltage from the alternator. Just a thought.
Mike
Well, I had a go at it last night. After thinking about it all day, I figured I would at least determine whether it was a fuel problem or an ignition problem.
I got the wife to crank it over while I gave it a shot of quick start at the air filter to see if it would at least fire. While she was cranking it, I could hear a loud 'snap-snap-snap' sound coming from the rear of the engine. Closer inspection showed that the coil wire was arcing out against a bracket by the distributor (this was aided by the fact that it was dark out!!). I moved the wire away from the bracket, sure enough, it fired right up!!! :seeya:
So I got a new set of wires for it. The old coil wire had an obvious pin hole where the wire was leaking.
Some problems are just never as complicated as they look!!
Thanks for the input,
Derek
Good job on figuring out the problem :D
I do want to offer some words of protection though. A hot wire sensor is hot enough to ignite anything flamable that passes through it. These would be MASS/MAFF sensors. There have been many explosions from people trying to spray starter fluid down the intake tube.
At 70K I would start being very concerned about my fuel pump. One of the best ways to diagnose a failing fuel pump is to find a shop that can current ramp the fuel pump and look at the pattern it produces, to see if the brushes and commutaters sp? are functioning properly.
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:     And another 15 minutes to find this clip out of Glenn Beck's video - the first few seconds is all the corporate media will allow the public to see, since the low IQ people will think Trump said " I love inflation ", and that was the end of it. Taken WAY out of context! Here's that part, plus the 2nd part about the oil smuggling operation:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
