Just Got Back
Truckman031
I just got back from duck hunting in Arkansas. It was a great hunt. We hunted Friday, Saturday, and 2 hours Sunday. I got 3 spoonbills, 1 Gadwall(sp?) and 2 mallard hens. I shot good, but still missed a few. The birds were working real good. Any body else been duck hunting yet?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
