Fuel Rail Covers
Has anyone tried to transplant the Denali or Escalade engine covers with fuel rail covers to a 1500?
I need some plastic to help hide the nitrous direct port. I like to conceal as much HP as posible:)
Haven't done it myself, but I saw a show truck at Super Chevy that had it done, although I think they used Corvette or LS1 style covers.  They should all be same underneath, but with different graphics on the top.  If you can find I set, I'm pretty darn sure they'll fit.
Jeff
