Brakepads...
I think I am in need of replacing my pads / bleeding out my brake system for my brakes feel spongy and have this ANNOYING squeek in the pedal too!
What do you guys suggest for pads? I have had good luck with raybestos ceremic pads in the past on my Jeeps..
Suggestions?
THanks!
Mike
I absolutely love my Praise Dyno stuff, it's more of a performance oriented pad and rotor. I have cryogenically treated slotted rotors and pads and it stops so much better than the original stuff, with no noise whatsoever and very little dust. I got front and rear pads and rotors and the e-brake shoes shipped to my door for less than $750. Here's the website if you wanna check them out: www.praisedynobrake.com.
If you're looking for a good long-lasting ceramic, I've heard some good things about Raybestos and ACDelco Durastop (which might even be Raybestos).
p.s. it still says you live in Florida...(a little different than the windy city)
Thanks!
I don't think I need new rotors at this time, they seem fine, and my pads may be fine also but I am hoping to get this mushey feeling out of my brakes!
I didn't realzie how bad it was until I had my mothers suburban when I was home over thanksgiving. AFter putting 800 miles on that I realized I need to do something..
I do realize that her suburban has 90 some thousand less miles...BUT still :chevy:
MIKE
Thanks!
I do realize that her suburban has 90 some thousand less miles...BUT still :thumbs:
MIKE
Mushy brake pedal, I would change the brake fluid, it sounds like you have water in the lines.
I'm really impressed with the factory pads. On my '99 Silverado I sold it with 125,000 miles on the original pads. The new owner has put another 25,000 on the truck and the brake guy told him to come back in another 25,000 to check the fronts, and maybe another 50 to 60,000 for the rears! I don't know any aftermarket pads that last like that.
Just my $0.02.
I use performace fricton pads from Auto Zone(lifetime stuff)In 96'I replaced the pads on my 93 caprice and I replace them every two years free set!(it gets driven hard)After 240,000 I replaced the rotors when I rebuilt the front end.The pedal was mushy in the caprice too,I replaced the brake hoses and flushed the fluid and it's fine. :thumbs:
-Steve
