Always a Star
99silveradoz71
From E!Online: "The Star is telling us Paris Hilton recently crashed a Hollywood producer's bash to try to schmooze a future role--nothing new there. But this time, she discovered she was already the star attraction. Hilton found party guests gathered around a big-screen TV watching her XXX-rated One Night in Paris sex video and slamming her performance. Needless to say, she jammed right out of there. Chin up, Paris. Bad reviews are part of the biz, girl--they're probably all just jealous. We'd like to see them do better. No, seriously, send us the tapes. Seriously!" :cheers:
