Question???
pipermaru9
Have any of you guys ever sold your Silverado to buy your wife a new car or truck? Was it an upsetting experience? Did you end up getting another truck later on? This is my situation although it might be a little easier in the fact she wants a Tahoe. Please, share your thoughts...
As a general rule of thumb..... If mamma ain't happy ..... Ain't nobody happy!!!!! :cheers::flag::banghead:
Yes it's tough to see your ride go, but this is just the beginning of sacrifices for you to make. :tear: But there is a way around it(kinda). Discuss vehicle options with your wife. Tahoe, truck, minivan and such. Then go checkout the vehicles of choice. While doing this wander over to the ec or 4 dr trucks. Give a few general commens about a "Truck would still be nice to have" After all this buy what she wants because you being upset is better than her "Hating what she drives". :smash: Telling you everynight for three weeks in a row at 3 am (personal expereince) :fume:
Maybe later you will get one if your nice now!!!! Maybe
Oh.... My woman wanted a 4runner. We looked around checked a few out. All the time me telling her it they were nice and i was fine with it. then she drove the Z71. LUCKY ME. It worked this time.
