Amsoil Users? What do you use?
I am looking to change out all of my driveline fluids to Amsoil products as I can get them pretty reasonable. What do you guys use? Front & rear Diff's, transfer case, tranny? Are there more than one choice for each? And how much do I need to do each of them? Want to pick it all up in one trip.
Thanks!
I just used the Series 2k 75w-90 for my front and rear diff, The transmission is filled with the AMSOIL ATF, it took 16 qts. My transfer case takes only the blue GM Auto Trac II. AMSOIL does not make a replacement for that yet. I have the push button auto 4 wheel transfer case. My front took just under 2 qts and the rear took just over two qts. The transfer case I can't remember but I think it was right at 2 qts as well but not sure on that one. Check your owners manual or someone on here might remember.
AMSOIL has come out with a new line up of gear oil. If you can't get the series 2k then the Severe Gear oil is what they replace the Series 2k with. It is $7.30 a qt and the Long Life gear oil is $5.90 a qt. It is one step down from the Severe Gear oil. The ATF is $6.00 a qt. If you get it for less than these prices your getting a seal of a deal. :ughdance:
If you have any questions let me know.
    MANGOAL
    MANGOAL
  • Who's Online   0 Members, 0 Anonymous, 471 Guests (See full list)
