No acceleration
Hi all,
I'm new to the board and havea need for some help (obviously).
I have a '97 G1500 that has a new intake manifold gasket to the tune of $600.
I am experiencing an acceleration problem - but I don't think it is related to the manifold work since it had similar malfuntion prior to the work.
The van will accelerate OK at about half throttle. After that, pressing the pedal further makes the engine bog down like it's starving for gas and it spits a little, but there is no acceleration. It will do this under load and in park. Tried it w/o the air filter in place for a few seconds, but same response, so that does not seem to be it. :ughdance:
It sounds like I may have a bad mass air flow sensor, a plugged catalytic converter or a fuel pressure problem, but I'm not sure where to start.
Any advice on how to start tackling this????
sounds like a cat to me. Is it glowing red after the motor runs for a while? You can hook up a vacume gauge and goose the gas and watch it. that will tell you if its the cat.
Thanks I'll check it out this weekend and will let you know...
A little more info.
I took it out and drove the heck out of it trying to see if the cat would get too hot.
Believe it or not, the performance actually improved significantly on the second day.
Not sure if the cat was partially plugged and it burned off or if the throttle sensor was dirty.
I'll keep an eye on it, but it appears to be operating as it should. :dupe:
  • 3 weeks later...
Try replacing the fuel filter. I have also had to drop the fuel tanks on a couple different vehicles to replace the fuel pump pick-up screen because it was clogged. I have also seen the coating peel off the inside of gas tanks and clog the fuel pump pick-up.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
