vid launch in my blazer
facn8me
thanks for the bandwidth J-rod
No problem! Awesome video and nice blazer! I wish I had something like that to play around with ... don't have the dollaz for all that though, lol.
:jester:
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
