Part numbers for Factory painted grilles.....
I did some research and found some part numbers for the factory painted grilles from Z71 Tahoes and Suburbans, that will also fit Silverado's.  Here they are in case anyone is interested.  This info came from partszoneonline.com
15770032 WHITE GRILLE
15770033 BLACK GRILLE
15770034 MD DK LICHEN
15770035 PEWTER GRILLE
Not sure what color LICHEN is, i'm assuming Green since thats the only other color those vehicles are available in.
Maybe you'll luck out and next year they'll up the number of colors offered in the Z's.  Of course knowing them, they change up the grille and sheetmetal too.
Probably, but I was thinking of doing mine all black w/ a red chevy logo so it would stand out more.  Then getting a black air dam (none of that grey junk, ugly, IMO).   But, I've got to get the time to take it off and paint it still.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
