Are nerfs apperance or 4x4
Any way I got some nerfs yesterday and put them on yesterday. 03 ecsb I got inexpensive one and am pretty impressed with the quality. I got the black powdercoat. Brand name Bully. Fit fairley well. I started at 6:10 pm and was home (i live 2 blocks away from work) by 6:50 if that tells you how easy an install. Brackets were sturdy doubt they'd take a 5000lb truck droppin on them, but it'll hold my chubby arse. ! thing they did make me realize Idon't believe I'll do a body lift. I was kinda 60/40 against but after realizing the factory bolts are like 6-7 inches long. A 3" body lift would call for a 9-10inch bolt. thats is pushing it in my mind in case of an accident. Probably never have a problem but i guess it still will all depend on my final tire wheel choice.
Pics up in a day or 2 . Current temp 24.7 morning will be 19 in the morn sunday should be 61 pics then. wheels with the income tax is next upgrade.
I put SS Bars on my 03 SLE EXcab  so the wife could get in easier
also I am told that small cars doors will hit the bar instead of the body
Yep me too. :fume: a million uses and counting. After pulling the moulding a few months ago I have been slightly nervous while waiting for the extra money for the nerfs.
New mod new pics :cheers: it's a sickness :eek:
Mods since last self gratifing plaster of pictures on the world wide web :D
Nerf bars
ventshades
Inner tubes with hose clamps holding the ends shut. :fume: Can be opened for traction aiding sand :cheers: and reclosed. Empty them after winter put in the garage. Just gonna miss the ride. :D
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 198 Guests (See full list)
