88 chevy problem
I have a 88 chevy C1500, 350ci, 4-barrel rochester. When I floor the the gas pedal it takes a second or two for any response then it kicks in and sort've jumps foward. What could be causing this? Thx
Could be a bad power valve/accelerator pump....while the engine is off pull the air cleaner and take a look down the primaries, move the throttle lever by hand, you should see a stream of fuel spraying into each of the primary throttle bores...the secondary fuel passages may be clogged also not allowing the extra fuel needed when the secondaries open.....just a couple of things I would start with
Check your choke pull-off to see if it's working. Also, you may have vacuum secondaries, which might have a bad vacuum dashpot. Vacuum secondaries are notoriously slow opening, but they get miserably slow when the vacuum dashpot is going bad.
I doubt if it's a fuel flow issue as then it wouldn't take off, ever. A bad accelerator pump would mainly cause problems starting out on primaries - it would act like it was starving for fuel.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
