1996 Sierra 4X4 (3rd Door Question??)
Hello Gang,
I looked at buying a 1996 Sierra 4X4 today from a local dealership.
It's a nice truck, but in his verbal diarrea, the salesman said it was a rare 3rd door truck and that they weren't officially made until 1997.
No biggie to me....but is he full of BS on this one???? :D
Much appreciated,
~Neon~
I had a 97 and it was my understanding that 97 was the first year that they made 3rd doors and that it was an option that year.
Full of BS. I know at least three people off of the top of my head who have 96 three door ext cabs. They were on the lot galore. The only thing about the intro of the 3 door that was a problem was Ford. Appearantley the new F-150 for 96(I call it the F-one-piece-of-s&*t) had some kind of patent right on the "3rd door" and GM had to wait until march of 96 to release their version. This is just what I remember, don't know if it is fact or not. Back to the original question, the dealer is lying and he probably made it up for a gimmick. Ask him a technical question like, what tranny, motor, rear diff it has in it.
Well....he even quoted me a number produced like 1,927 units like he sleeps/eats/breaths this stuff, so I was just curious. :D
It's not going to make the sale (it is a bonus as I have 2 kids though!!)
Thanks Guys,
~Neon~
Interesting...did a "Google" on the 3rd door.
Apparently it WAS the first year and an option at the time for the 4X4 C/K 1500 models ONLY.
http://www.canadiandriver.com/articles/jc/88-98sierra.htm
and.... there was a problem with FORD when introduced.
http://www.findarticles.com/p/articles/mi_...v32/ai_17815581
so i guess in a way...everyones right :D
Thanks again,
~Neon~
Thanks Guys,
~Neon~
I also have a coupl little ones (4&6), the third door is not all its cut up to be with them but it is functional and they certinally love cruz'n in the truck.
Well....he even quoted me a number produced like 1,927 units like he sleeps/eats/breaths this stuff,  so I was just curious. :loser:
Thanks Guys,
~Neon~
Not sure what you mean Ivan?? :D
Mine are 8 & 10 yrs old......
Hard to get in?
Not much room?
Uncomfortable?
~Neon~
If I remember correctly, Ford introduced the extra doors on their 1997 models in 1996. They launched the 97 a year early to beat GM to the punch. I know that there were 96 250's and 350's, but I am not sure about the 150. The GM, I remember there were 3rd doors avaiable in 96, but not many just yet, 97, they became more prevlant, 98 I believe they were standard. Just my thoughts.
I was a buyer in 96 and the 3rd door was indeed an option. Initially, they were only produced in the Oshawa plant up in Canada for the entire North American market so there were some supply issues. That may be where the salesman got the impression that they were rare.
I can tell you this. I couldn't get it on my truck because an automatic transmission was a manditory option in order to get the 3rd door. Mine was a custom ordered fully-loaded Silverado right down to the leather seats but I wanted the M50 5-speed. The owner of the dealership even tried to get this 3rd door option pushed through but GM wouldn't budge. It took almost 4 months for it to arrive.
Yep,The 3rd door from '96 to '99 ('99 being OBS that is) was only available on the 1/2 ton short-bed trucks with either the 305 or 350 V8's and the M30 auto.trans.
Plus you had to get the "Silverado" pkg., it was not available on the base models.
The 3rd door was optional from '96 to '98 (RPO Code E24) and became standard in '99 (On both the OBS trucks and NBS trucks)
Has anyone ever seen a OBS ext. cab duallie with the 3rd door? I don't think they exist, I have never seen one any way.
They're like mermaids.
Just because you havn't seen one, doens't mean they don't exist. :D
"Y'know, I seen me a mermaid once. I even seen me a shark eat an octopus..."
Loved that line.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
