THE BEST IRISH JOKE
bummed-n-Md
THE BEST IRISH JOKE
John O'Reilly hoisted his beer and said, "Here's to spending the rest of me life, between the legs of me wife!"
That won him the top prize at the pub for the best toast of the night! He went home and told his wife, Mary, "I won the prize for the best toast of the night."
She said, "Aye, did ye now. And what was your toast?" John said, "Here's to spending the rest of me life, sitting in church beside me wife."
"Oh, that is very nice indeed, John!" Mary said.
The next day, Mary ran into one of John's drinking buddies on the street corner. The man chuckled leeringly and said, "John won the prize the other night at the pub with a toast about you, Mary."
She said, "Aye, he told me, and I was a bit surprised meself. You know, he's only been there twice in the last four years. Once he fell asleep, and the other time I had to pull him by the ears to make him come."
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
