Gas mileage
I drove my truck to Florida and back,from central Pa. about 2,100 miles round trip, I got about 16 mpg., is this typical of these trucks, I thought it would do a little better than that.
Hey 95 Silverado,
I live in Central PA (Lebanon).  I take it your from around the area.  Anyway I get about 18 MPG.  However, I have 305 with 100% freeflowing exhaust, and an air intake.  Considering that you have a 350 with a 5-speed, you are doing ok.  By the way, did you order that NV-4500 when you got the truck.  I would kill to have that tranny.  I have the wimpy NV-3500.
FunInTheMud
thanks for the replies, I wasn't complaining about the 16 mpg. just wondered if that was average.
Fun in the Mud, I'm from Altoona, I didn't buy this truck new, I bought it used earlier this year. I'm guessing the transmission was part of a tow package, being that it's a 1/2 ton truck. It also has an engine oil cooler, factory hitch, and 3.73 gears. I almost didn't buy the truck because it was a 5 speed, I wanted an automatic, but it had everything else I wanted, I found out after I bought it that it was the heavy duty transmission. It works great, but I may change it over to an automatic. It's nice on the highway, but it's a pain shifting in town.
With the truck in my signature, I can't get anywhere from 16-19mpg on the highway, depending mainly on how fast I drive.  Its normally right around 18mpg, which I am very pleased with since she has right around 155k miles on her.
My brother has a bone-stock '95 Z71 sportside (stepside) with 350 & automatic. He drives about 350 miles from FL to GA for hunting. On those trips he's gotten as much as 20+mpg but averages 17-19mpg depending on speed, load & wind conditions.
Hey 95 Silverado,
If you decide to change over to an auto, would you consider selling your NV-4500?  I would love to have that granny gear.  My truck was optioned with the engine oil cooler and a 3.73 rear as well.  The only thing I wish it had was posi.  It sucks when its wet out.  I spin all over the place.  However, if I put it in 4wd, its a different story.  I agree with you that shifting is a pain in town, but its also nice to bang gears.  "If you can't find them, then grind them"
FunInTheMud
Fun in the Mud,I'll definitely be looking to sell it if I take the 5 speed out, it won't be before summer though. I'll let you know. I hope to add a posi to my truck also, used ones are hard to find, I'll probably go with a new eaton unit.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
