Mirror with turnsignal ?? connector??
Hello
This may have been asked before but I did not find anything on what I would like to know,
Does the trucks that do not have the turnsignal in the mirror have the Same harness in place as the ones that do??
I was wanting to upgrade to them but did not want to do any extra wire running..
this is on my 04 HD silverado.. It had the harness in place already for the fog lights and they worked without programming..
I assume GM uses the same harness for most all truck?
Please Help me out on this one.. Thanks
The harness will be the same but it depends on what you are upgrading to. If you currently have mirrors that are not power folding, heated, curb assisted, and auto dimming, your upgrade to ones that are there are some concerns. Your power mirror adjustment button must be capable of the power fold and you must have a rear defogger and heated mirrors now or these functions are not accessable. The defog feature probably has a relay somewhere in the electronics to control the heat. If you already have these features then you are good to go. If you want the curb assist feature to work properly you will have to have your PCM flashed. You need to post more detail about the options that already exist on your truck. I am not posative but here is a list of features that are on the deluxe mirrors.
integrated blinker
power folding
heated
curb assist
auto dimming driver side
If you add some detail I am sure there will be even some more knowledgable replies than this.
Thanks for the reply, I guess I should have added the specs/detail of what mine has.. My Bad,
anyway mine does have the power heated mirrors. I have the rear defogger also,
I don't think the power folding or extending would work as I do not have the switch for such.
I was thinking though that the mirrors with the blinker in them may plug to my harness and work?
right now I have the manual folding style that is heated and power adjustable.
Sorry this is so long....
I don't care if they are the extending or power folding.. I just want the blinker feature.. I figured GM would use the same harness/connector for the non blinker power mirror as they do for the ones with the blinker in them?
Thanks again for the help.
one more, If I was to replace the door switch to one that is for the power extending mirror the harness would work for that??
That would be Great if I could get the switch and the extending blinker heated mirror and just plug in and all work..
The harness will have the blinker feature already there so if you purchase the blinker integrated mirrors they will work. The only reason I was really curious about your options is that the blinker mirrors are only available with all of the other options(I think). When I ordered my 03 it was this way. If you have to pay the money for the mirrors with the folding motors built into them already you might as well spend a few extra bucks and buy the new switch and PCM flash(for the curb assist feature and auto dim). I know you said you did not care but, if they're equiped, what the hell. I have the power extending(regret that option). I have had to fold them in alot more than extend them and now wish I had stuck with the smaller power folder than pay $275 for the camper extenders.
Cool, so sounds like I should be in business then, I would like to have the extending feature as well as the blinker and so on but figured it would not be possible without alot of trouble.. I think I will look for the switch and a pair of the extenders then with the blinker in them..
I think you can get them with being only Heated, Power, Manual folding, and then the same with the blinker option as well..
then there are the others with curb assist, power folding, power extending and so on... they have 4-5 styles I believe..
after thinking about it I would like to end up with the power extenders heated with blinkers.. with as little mods as possible. the extend feature would be a nice plus as well..
I think in order for the "curb view assist" to function you must have DIC with steering wheel controls.
Would that be just the curb assist?
Yes, the curb assist is the only mirror function thats needs the steering wheel controls to turn it on or off, the other features will require the proper mirror switch in the drivers door module and programming of the BCM. The heating will only work if you have the rear defroster. The auto dim will only work if you have the auto dim mirror on the windshield, that is where the sensor is.
    KP1
    KP1
  • Who's Online   4 Members, 0 Anonymous, 771 Guests (See full list)
