85 C20 Crewcab Longbed
I think I may have made a wrong turn here, you guys all seem to have such nice trucks and mine ... well its a work truck.  Gotta love it though, its like a family car and a truck all in one.  I love it so much I bought a high $$$ 350 to replace the 305 that someone else had put in it to replace the 350 that came in it.  Confusing?  try replacing a car motor w/ 2 smog pumps & a million vacuum lines with a hot rod 350.  I know my truck came w/ 350, 1 smog pump, dual exhaust & no cat.  But I'm having a hard time visualizing what it has to look like for emmisions sake.  My question, does anyone have any ideas of where I can find a pic under the hood of a stock 85 truck w/ 350?  I even looked into buying an older truck to get out from under some of this but I love that great big 4 door monster.  Once again any ideas would be appreciated.   Thanks, Mark
If you can find someone who has the GM microfiche listings for that generation,it will show you what you need to know in detail.If you can't find an individual who has it try a dealership or a library.
Boy that's a though one. I have a converted 86 trans am. but I live in an area that doesn't have emissions tests. I just kept the cat and converted everything else to pre-emmisions junk days.
I would go to www.camaroz28.com and post in the Third-gen section about 305 to 350 swaps.
It would surely make things easier if you didn't have to worry about emissions.  I had a 83 Buick Regal that was just covered in vacumn lines and other junk.  I could handle a motor swap in my truck as the motor compartment is pretty clean, but couldn't imagine doing your project.
Could you find a similar truck and get a good look at it.  I'm sure someone would be friendly enough to allow you to do that.
Thanks for the replies.  I guess I'm going to have to take the easy way out and do the swap as best I can and drag the hulk (and extra parts) down to the mechanic and let him and the emmisions specialist hash it out.  Maybe I will be able to work on it myself when they lose the crap it don't need.  I'll just have to wait till next month for those Thornley Headers.
  Here's a ?? for you guys.  Keep in mind my truck has been sitting out in the elements for a couple years.  I was going to take the gas tank off and get it cleaned out so I wouldn't be trying to run any crap through my new engine but I'm running out of time and enthusiasm for this project.  Do you think it would be good enough  to throw some high grade gas and some Heat or     something else to get rid of any condensation in the tank.  I almost ran it completely empty when I parked it and it has a locking gascap so I know nothing got in that way, as a matter of fact I will have to find my keys if I want to put gas in her.  Is there a better product than heat?
  By the way I'm getting pics of the whole train wreck ( I mean rebirth ) developed on cd so maybe I can post some when the time comes.   Thanks again,  Mark
Mark, if you had been here 6 months ago I still had my 86 GMC with the 350, but the only problem with it would have been it had CA emmisons(sp) on it.  It took Reg. gas and had 2 yes count them TWO smog pumps on it, and I bought it brand new from a dealer in AR.  We don't have testing here so I took the pumps off of it after 12,000 miles, the exhaust manifolds were like imation headers each runner was about 3 to 4 inches long.  I looked around for other manifolds and could not find anything else like them.  My ideas on it is if you can get it to run without any smog stuff you'll be better off.
I agree with doverarjim. if you can get away without the smog crap, do it. Just get your rig running healthy and all that smog stuff doesn't do much anyway.
Also, I've had Doug Thorley headers (I think that's what you were referring to earlier), and had bad  juju with them. They leaked, I was constantly trying to get them to fit the heads right by trying different gaskets, alternating my tightening sequence, leak tech and mud, you name it. I bought some Hookers and had no problems whatsoever. Hopefully I just saved you some $$$ and heartache.
  Well I got the engine and tranny installed yesterday, almost complete. A few remaining parts that wouldn't make the install.  Several new parts I had to buy since the ones on the engine wouldn't fit my truck.  Went ahead and put both smog pumps on it so I wouldn't have to have my mechanic do it to get emmissions, figure I can just take the belt off the pumps after the fact.
  Friz I thought that 3/8" flange on the Thorley's guaranteed no warping or leaking, I will definately have to check into that.  I put my stock "mock" headers on for now because they bolt right on and I may not be done replacing parts yet to get running.
  Sometimes I wish I had started with a crate motor, all the spare parts I've got into this one is really getting up there.  That's why I bought this motor, cause it had all the parts.  I had to replace the cam with one less suited for drag racing and more suited for driving ? maybe towing.  That hurt.  But this way I got a block with 4 bolt mains completely machined, some killer heads, and nice intake and carb.  Was it worth it?  I hope so.
  Got some pics being developed on CD,  What's the best way or place to put them on the internet?  Thanks for the feedback.  Mark
Gotta Love Them 4-Doors
Ya know what? It is a proven fact in the law of mechanics that if you disassemble and rebuild your motor, truck, dirt bike, or whatever enough times, you will be left with enough spare parts to completely build an identical twin.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
