New guy here
ArrestMeRed88
Hi guys. I just started on a little project... ok a big project. I am a member of thirdgen.org and now this site. My project is a 1988 Chevrolet Silverado 1500. going from a stock 350 Fuel injected to a track worthy 454. Truck needs paint etc. but the hardest part will be getting the 454 :D but when it's done it will be well worth it :cheers: anyways. My daily driver is a 1986 Pontiac Trans Am but you don't care to hear about that.
Anyways for pics of the truck go to http://www.cardomain.com/memberpage/759536
Talk to you guys later.
James
