Vararam VR-6 King Cobra
ZL1
All interested: FYI
Wednesday, January 26, 2005
Carol (TByrne Office Manager)
1227 Horseneck Road
Westport Ma. 02790
Dear Carol,
Subject: RA #xxxxxx
I regret to inform you that I am returning the Vararam VR-6 induction system I ordered. It will not suit my application requirements. My initial concerns emerged during unpackaging/receipt inspection, however I did afford it the benefit of doubt and continued assembly/installation. Once installed multiple unacceptable flaws became apparent:
1. Poor Filter Quality: a thin layer of cheap foam rubber will not suffice for dusty off-road conditions.
2. Difficulty of filter maintenance: the entire system must be disturbed to clean what remains of the thin foam filter.
3. Poor unit structural integrity: only one support bracket for the ram air secondary scoop; the rest of the system is hanging from my stock air inlet flex hose. This arrangement will not survive off-road conditions.
4. Loss of stock grille structural integrity: unit installation requires the removal of the stock upper grille support, which reduces the rigidity of the grille; this also disturbs airflow through the A/C condenser and radiator.
5. Inadequate component-to-hose connections: the tapered air box/scoop connection flanges lack any type of hose barbs to preclude the hoses from working away from the air box/scoops over time. This problem was very apparent during initial assembly. I am aware of and accept your required 20% restocking fee. All components are as received, unaltered and packaged in the original shipping container.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
