Common issues and Solutions
I'm starting a thread that lists all of MY problems and a link to the thread that helped fix it.
Please, add YOUR own issues/solutions to this thread as well, it should help alleviate some posts and provide a central location for solutions.
1999 GMC Sierra 1500 4x4 5.3
Ext Cab
New Body Style
1.) Fuel Sender Unit failed - fuel gauge stopped working - (~50,000 miles) - Click here for solution
Haven't fixed this yet, just using the odometer and refilling every 300 miles
2.) Leaking rear window - (~50,000) - Click here for solution
Used a silicon bead on seal, working fine so far
3.) Back rear speaker went out in the 3rd door (~60,000) - Click here for solution
Replaced myself
4.) ABS Light - EBCM Unit switch is dead - (~80,000) - Click here for solution
Sent the unit off, got it back within 3 days, just installed it and it works great, the guy saved me $800
  • 3 weeks later...
  • 3 months later...
7.) Every light in the factory Delco CD player/radio burnt out (. . .within a month) - (~80,000)
Went to radio shack, bought about 9 simple light bulbs, soldered them in - GOOD TO GO!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
