air intake!!!!!
I need some help!!!
I have a '93 tbi 350.
If I take the factory intake off and put an open filter on do i need to recalibrate the computer for a new fuel air mix????  What type of setup should i go with??
The computer will recalibrate itself to the increased airflow within about 100 miles.  One thing you might want to do to speed the process up is disconnect the battery after you change from the factory intake.
He's right, the new trucks have a "learning" computer and are supposed to reprogram themselves for changes you make.  Taking off the battery terminal is the better way to go because the computer will loose it's settings and "learn" how the truck will run w/ the new set up.
