Toy Factory...
Bgdsub72
There is a factory in America which makes the Tickle Me Elmo toys; it
laughs when you tickle it under the arm. A new employee is hired at the
Tickle Me Elmo factory and she reports for her first day promptly at 0800.
The next day at 0845 there is a knock at the Personnel Manager's door. The
Foreman from the assembly line throws open the door and begins to rant
about the new employee. He complains that she is incredibly slow and the
whole line is backing up, putting the entire production line behind
schedule. The Personnel Manager decides he should see this for himself so
the two men march down to the factory floor. When they get there, the line
is so backed up that there are Tickle Me Elmo's all over the factory floor
and they are really beginning to pile up. At the end of the line stands
the new Employee surrounded by mountains of Tickle Me Elmo's. She has a
roll of plush red fabric and a huge bag of small marbles. The two men
watch in amazement as she cuts a little piece of fabric, wraps it around
two marbles and begins to carefully sew the little package between Elmo's
legs. The Personnel Manager bursts into laughter. After several minutes of
hysterics he pulls himself together and approaches the woman. "I'm sorry,"
he says to her, barely able to keep a straight face, "but I think you
misunderstood the instructions I gave you yesterday. Your job is to give
Elmo two test tickles".
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
