2001 factory radio
2001 chevy tahoe, recently pulled out the factory radio and found a wiring nightmare!!!!!!! previous owners hacked the $#!^ out of the wiring harness and I am trying to clean it up. my problem is some wires aren"t connected and the aftermarket connector's wires ofcourse don't match. does anyone have a wiring diagram and connector pin position illustration they would ever so kindly like to share with me???!!!
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
