BassLink T opinions? Advice? HELP....
as in the topic, Will the BassLink T fit behind the rear seat of a 2005 CrewCab?
looks about like it would but not sure.
does anyone have one installed in a CC? could you post a picture or 2? also anyone with one how do you like it? seems one would be plenty for a truck not wanting to win any thumping awards but should still fill the cab with the needed bass..
Hope to hear from several with them..
I just got my 05 Z71 1500 Crew cab last week and was wondering the exact same thing. I had a basslink from my car that I wanted to install in the new truck. The basslink will not fit behind the back seat of the 1500 crew cab. However, it will fit under the back seat. My only concern is that is may be a little too tight, and the amp may get too hot? Also, you will not be able to fold down the back seat. I'm going to my local sound shop tomorrow to see what they think. In the meantime, I'm also trying to find a box that is made for the 05 Crew Cab, if I can find one I may trash the basslink idea. if you have a 2500 HD crew it will be a different story
Thanks,
Yep mine is the 2500HD. I will have to check the difference of the 1500 and 2500hd for space behind the rear seat. sounds like though one of the basslink box's may not fit then..
why would it not work in yours? to deep, tall, or both?
Thanks
I've got one of those as well in my '03 extended cab. Fits perfectly under the extended cab back seat.
However, unless you are willing to raise the seating for the crew cab, you are out of luck. The BassLink will not fit under or behind the rear seat. Shame too, I like the BassLink.
  • 3 weeks later...
I just purchased a BASSLINK for my 03 crew hd and it seems to fit under the LR seat. Kinda tight but it works just as long as no heavy people sitt on it.. NOW I just need to figure how to hook it up ANY ONE know?????
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
