NASCAR style silverado
I know it sounds kinda random but a friend of mine is getting a new RCSB silverado 4.8L w/ a 5spd. Had to go for the 4.8 to get the manual. Anyways he kinda wants to go w/ a nascar styled look. Black wheels lowered exhaust in front of the wheels. Question is, has anyone seen one or have a pic? I know ford made one and that's kinda what he is going from. oh yeah, it's silver birch. any comments, suffestions?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
