photos: moldings removed
i removed the body side moldings and what an incredible difference it
makes in the overall look of the truck. i wish i would have done it
years ago. i put some pics to show. ALSO, i am a new dad today, of my
second bullmastiff. AND ON THE EIGHTH DAY GOD MADE THE BULLMASTIFF
truck
looks alot better. I pulled mine off in a resturant parking lot after realizing some one put a huge scratch in it. btw...congrats on the new pup!
It looks real good.  I'm trying to convince my dad to take his off of his 05.  BTW, cool dog.
Problem is is that they do serve a purpose and after you get your truck dinged several times from car doors you will wish they were back on.
I can agree with that too... I got a door ding 3 days after I removed them and right where the molding would have been too... :chevy::banghead:
I have spent waaaay too much money on the Blazer because I took the trim off when I bought it 10 years (or so) ago.
It still has 4 or 5 dings on it that just twist my toes every time I see them.
But it sure does look good without the trim. :chevy:
So does yours :banghead:
Looks good. I've bene resisting the urge to take mine off. Wife's Z-71 Burban does not have them, and she only has one good door ding in two years...but her Burb is white and doesn't show the dings like my dark gray. Hmmmm...what to do?
I put some 7 inch wide molding from a Youkon XL 4wd on my dually to hide a dent in the rear passenger door. To have the door repaired, the paint shop would have painted 1/2 the front door and 1/2 the rear fender to blend the paint.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
