Hello, Newby here
Chuck21387
Just thought i'd say hello, i'm new to the board. I've got a 1986 GMC Suburban with 6" susp lift and 3" body lift, running 44's, well at least it was till it caught fire a year ago, i'm now in the process of rebuilding it, for sentimental purposes.
I'm new also. just thought I'd reply. I have an 89 Chevy K1500 and a 2004 GMC 2500 HD.
I'm "new" here also. I've been a lurker for a while now and just figured I'd sign up and say hello. :seeya:
I :thumbs: an 03 Silverado ECSB Z71
This is a great site and I hope I can contribute somewhere along the way. :cheers:
time to pull out the weed eater again for that initiation!!!!
guys, I suggest we up the requirement to use that cool titanium infused weed eater cord????
Welcome!
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
