New tailgate cables stick out
After getting my new tailgate cables cuz of the recall, I noticed that these new cables stick out the back end of my truck. They stick out in the gap between the tailgate and the tail light.
Anyone else's do this?
Any fix to this? Cuz it looks stupid.
Mine does on the right side only, I just open the gate again, line it up better and close it. The cable stays in.
That's probably because they didn't do the job correctly. There are two tiny washers that have to be put in the right location to allow free rotation of the cables. If they put 'em in wrong (seen it many times) or don't put them in at all, the cable eyelet will bind at the tailgate end.
Open the tailgate all the way then and lift it up 6" or so to take the tension off the cables. Can you rotate the cables at the tailgate end with absolutely no resistance? If not, take it back. The insulation on the cable is probably chewed up now too.
Another common problem is the dealer puts the cables on the wrong sides, that will cause them to stick out exactly as you describe.
They are marked L and R and must be installed on the correct side.
Duct tape? Sorry, long day.
Same with mine. Only sticks out on the right side.
Then you probably have two lefts or two rights. They are marked clearly on one end, I forgot which end.
I didn’t notice a left or right decal but I did see the MADE IN CHINA decal. :thumbs:
Not a decal, the L+R are stamped right into the metal. If they are on the wrong side, they will stick out. Most dealers aren't aware they work on only the side they are made for.
IF THEY STICK OUT THEY ARE ON THE WRONG SIDE, SWAP THEM!!!!
Mine don't stick out but i did get the custom unequal length ones.  :cheers:
Mine too. That's awesome :thumbs:
    250.3k
    Pro Street Jim
    Pro Street Jim
  • Who's Online   2 Members, 0 Anonymous, 435 Guests (See full list)
