Hey LiftedHDRado.........
Can you tell me about the ride quality difference that you've noticed since installing your Cognito lift?
I'm very new to researching suspension lifts, but in doing some research, Cognito really caught my eye.
One thing that I liked were the different options that were available.
Your truck looks awesome!
The oldguy
