license plates
forgive me, but it is truck related (kind of)???
for several months, i've been looking all over the place for a "Beef it's what's for dinner" front license plate.  I have tried everywhere i could imagine and no-one has one.
does anyone know where i could find such a thing?
they have them on the Beef.org website but you have to order 25 and i only have 2 vehicles so that doesn't help me.  i know, i know it sounds like a corny request, but dang-it, it's my truck
thanks in advance!!   :)
Actually, I took the dealership plastic plates and put my website sticker on them. They look really cool and "professional" lol! I'm thinking of making some more and selling them! any buyers?
