Rear Differential Change
I'm changing the fluid on the rear of my truck. I went to clean the magnet and it came off. I put it back on and it stays but can be moved around with a fair amount of pressure.
Is it supposed to come off like this or is it supposed to be glued on?
Thanks, not much metal fuzz on it -- The rear appeared to be pretty clean.
This is on my'04 with 10,500 miles.
All the times I changed it on my '01 the magnet has never come off.
You can "stick" it back one with Black RTV form a gasket sealant (you can get it at Advanced Auto) it takes about a day to cure though but oil will not effect it at all when cured.
I have seen plenty that way and it wont hurt anything. I personally like it to come loose so i can clean it better.
I think they are just held in place by magnetism. I've never seen any adhesive on them. I always take 'em off to clean them better also.
You might just have a weak magnet. Could get a new one...
But it sounds like it's always been that way, so I'd probably just magnet it back where it goes and close it up.
This is true but the RTV would not be hard to remove if need be if you are concerned about it staying in place.
    FiLo
    FiLo
  • Who's Online   4 Members, 0 Anonymous, 454 Guests (See full list)
