Rear View Mirror display flaking out
71GMC_3/4T
GM-Tech,
My Compass/temperature display flaked out the other day.
It has OnStar, but it's not activated.
Both green LEDs (on/off and Onstar) would go out along with the display, and a second later the LEDs would come on and the temp/compass display would light up all the segments and then show the temperature and direction for a couple of seconds, then it would blank out and do it all over again, and again...
Since both LEDs and the display all went out at once, I'm suspecting a bad ground somewhere.
Does the mirror assy get power from two different locations for temp/compass and Onstar?
Is there a ground above the headliner that might be bad, or a ground somewhere else that might be loose? I think wiggling the wires above the mirror may have helped it, but it was so intermittant I really couldn't tell.
The problem happened Thursday night, and hasn't come back since. :chevy:
Any insight you could provide would be great! :jester:
Thanks!
Everything shares a ground, but what turns on the various things is different, so I suppose it could be a ground. There's a splice pack right at the bottom of the left pillar molding that contains a number of grounds, so I wouldn't think the problem would be there, otherwise you'd lose more than just the mirror. More likely, something right at the mirror connector, but that's a guess.
Thank you sir!
I'll go pull the mirror assy off the windshield and take a look inside.
What's up w/ GM's solder quality? Did they recently make a switch to lead-free solder or something? I've already had to reflow the solder on my 4x4 selector switch after it flaked out and went blank. By the way, that problem hasn't come back since on the 4x4 switch.
I was looking for something to do this weekend - crappy weather sux bad...
I'll let you know if I find or f-up anything!
Lead-free solder :jester: That's a good one. I honestly don't know what the problem is. I guess when you get into mass producing millions of parts, things can happen.
Lead-free solder  :lol:  That's a good one.
Actually, it's for real. :chevy:
The world is switching to lead-free solder for electronic assemblies. It's starting in Europe next year I think. I noticed the mirror had an IEC number on it, and that's where it all starts, with IEC... I think it's all :jester: , but there probably *is* a lot of lead being dumped in the landfills.
Anyways, I pulled the mirror off and took it apart. Man, there's a lot of circuitry in there! And a lot that isn't stuffed, like LEDs that would shine through the center bottom of the mirror. What are they for? Radar detector??
The main connector had 3 pins tied to the ground plane. I reflowed the solder on all the pins to that connector. I have to assume one ground pin is the main return, and the other two grounds go on to other modules.
You're right, they have different sources which I confirmed tonight. When the key is in ACC, you have OnStar LED only. IGN gets the compass/temp and AutoDimmer mirror, and still ONstar. So for all of the indicators to flash on/off at once, it would almost have to be an intermittant ground.
Out in the front of the mirror is a box with two little things that look like relays. Are these the compass sensors? They are mounted 90 degrees from each other.
Dunno. Never really looked that closely at one. Doesn't work? Got power and ground? Replace it. That's as much as we get into it. :jester:
GM-Tech,
The problem happened Thursday night, and hasn't come back since.  :confused:
Any insight you could provide would be great!  :tear:
Thanks!
Mine has done this several times over the winter months and once during a cold rain. Hmmm... Cold / Moisture related bad ground? I haven't had mine looked at yet by the dealer.
Mine did it last week when it was sunny and warm in the morning, and by mid-afternoon we were getting hammered with snow. Ahhhh, Colorado! Gotta love the weather here...
I think it was due to the rapid temperature change. A quick change like that will uncover all sorts of weird intermittants. I think I had something similar with the 4x4 selector switch too. It sat where the sunlight warmed up the dash on that side, then when the sun went down and I went to go home, it flaked out.
I've reflowed the solder on both the 4x4 selector and mirror assy. I haven't had any issues with the 4x4 module since, and it's too soon to say whether or not the mirror is fixed or not. Yeah, I coulda taken it into the dealer, where I would have gotten the runaround since it would have probably worked just fine at that time. And if they had found the problem, it would have been a full module replacement, likely just as bad as the old one, waiting to fail at a later date out of warranty. This way, I know how well it's soldered. I used some really nice silver bearing electronic solder when I redid them.
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 790 Guests (See full list)
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
