Service 4WD message
Well I know it's a common problem on these trucks, but I got the "Service 4WD" message on the DIC as I was driving home this afternoon. Also the lights in the switch itself are not burning.
Does that sound like the symptoms of a bad switch? Also, I assume if it's just the switch there's no problem with driving it????
Got appointment with dealer tomorrow @ 2:00. No real sweat as it's a warranty issue, just wanted to see if this sounded like the same problem to those of you who've seen a bad 4WD switch.
vroten :P
Yes, it sounds like a bad switch. Mine did the same thing. No lights, no backlights, no worky. The fact that the backlights AND the switch indicators were out tells me it was a faulty ground.
I wouldn't know if it will screw something up by being bad or not.
When mine flipped out, I shut it off, pushed all the buttons a bunch of times and turned it back on and it worked. The next day, it worked fine.
I pulled it on the following weekend and reflowed all the solder on the connector pins and it hasn't failed yet (~2 months). Yes, it probably would have been fixed under warranty, but now I know the solder is right and shouldn't fail ever again. A new switch seemed like a problem waiting to happen again.
IT CAN BE TO THINGS EATHER THE SWICH OR INSIDE THE INCODER MOTOR MOD ON THE TRANFER CASE, BUT BEFORE REPLACEING EATHER ONE
GM HAS A TECH SERVICE BULLETIN ABOUT THIS PROBLEM. WHICH TCCM NEED TO BE REPROGRAMED
Like 71GMC_3/4T said: After I let the truck set for about 1/2 hour when I re-cranked and everything was back to normal. Wondering about the TCCM (?????) reprogram. Is there a bulletin # on that?
thanks
vroten :P
I believe Bobcatt5544 was right. Seems if it were a switch the problem wouldn't be intermittant The dealer did a reprogram on the TCCM.....seems to have fixed the problem...... hopefully. Thanks for the info Bobcatt
vroten :P
Roden,
I read the TSB verbage you posted the link to.
I'm wondering if you need to do this with the key on or off, or does it matter?
Thanks,
'71
Roden,
Thanks,
'71
I'm pretty sure I did it with the engine running. I'll add that I never had the TCM thingy reprogrammed. I figured I'd do that if the thing kept acting up. So far so good.
BTW, sorry about the late reply--I'VE BEEN AT THE BEACH!!!
:D
