What gearing in rear end?
On my 89 Sierra 4x4 with a 350 I have a 6" superlift and 33's. On the freeway when The truck shifts into overdrive it seems to bog down alot and I will have to give it more gas then it shifts out of overdirve. What gearing would I need to make it like stock gearing or lower?
You most likele have 3.42 or 3.73 gears from the factory.
Try and see if there is an option for gears around the 4.30 range for your truck and if not,4.56 would be the way to go,IMO.
I'm not really sure what gears I have right now. I'm guessing their stock.
You can tell what gears you have by looking in your glovebox.
Look for a code, they are:
GT5-4.10
GT4-3.73
GU6-3.42
GU5-3.23
Hope this helps ;)
I guess 4wheelparts.com would be a place to go.  There are some more places, but you'll have to find what you want and just shop around.  You've got time.  If you get the gears and tires from the same place I be they'll cut you a deal.
