06 VORTECMAX
I am thinking about downsizing from my 04 HD2500 8.1 to a new 1500 VORTEX MAX performance truck.
What transmission is it using? They say its an M70 on the order info but I can not find out if its a 4l80 or 4l60 or what ever.
I am thinking that this truck sould be good for 7,500 lb trailer.
I have the 8.1 now but its a killer on gas and I just down sized from a 9,000 trailer to a 6,500 loaded rig.
Any thoughts on this new truck.I had an 03 HD1500 with the 300 hp version and really liked it so with a lighter truck and an extra 45 horse it should be pretty nice.
Thanks
Phil
In our parts catalog for '06 the M70 is listed as a 4L70-E SUPER-DUTY,4 SPD. A/TRANS.
I can't tell much more than that right now because we don't know much more than that right now! but I hope this helps give you a little more information.
And yes,This sounds like a hell of a truck,I wish I would of waited for one.
There was a post a while back on the heavy duty forum asking when the 06 3500 info was available and it linked it to a GM website that had a lot of info on the 06 stuff.
They have 2 trucks with the high output 6.0.I think one was a 2wd with 3.73 gears and a 4wd with 4.10 gears.both with the 345 hp 6.0.
The "VortecMax Performance Package" (RPO Code "NHT") is a package that gives you....
LQ9-345 horsepower 6-liter V8,
M70-"Super-Duty" 4-spd.Auto.Trans.,
GT5-4.10 Rear Axle Ratio,
G80-Locking Rear Differential,
ZX3-Ride-Control Suspension Pkg, (Z71 Suspension Pkg. Not Available)
NP8-Autotrac Transfer Case,
KC4-External Engine Oil-Cooler,
KNP-External Tranny.Cooler and
Z82-Heavy-Duty trailering package.
Its only avalable in the 1/2 tons w/4WD in either the ext.cab short-bed or crew-cab short-bed.
Thats all us dealers know right now.
Thanks for the info.Would you know what the tow rating is?
I saw that with the 5.3 and 4.10 was 8,000 plus
Nope,Sorry but as of May 27th they(GM)didn't have the tow specs on it yet.
And the 5.3 w/ 4.10's is rated at 8,700 lbs in an ext.cab or crew-cab 4WD 1/2 ton.
"Its only avalable in the 1/2 tons w/4WD in either the ext.cab short-bed or crew-cab short-bed."
:D
Of course. Why would I think otherwise :ughdance: ???
It really gets old..... I wish GM would pull it's head out of it's butt :bs:
That transmission sounds sweet... any other specs on it ??
What's the advantage of this truck? How close will the price be to a 2500HD? Wouldn't it be more cost effective to get a 2500HD w/ 6.0 for towing? I'm just thinking you'd get a heavier built truck (axles, brakes, etc.) for similar money. I'd sure like to know what it's gonna run though, 345 horse would be sweet, could drag my Ski-Doo's around.
It doesn't sound like they are releasing it for the "Towing" group, more for the "Sport" group.... probably going to be along the same lines of the "Rumble Bee"s and the "Daytona" Dodge Rams I see floating around..
I agree with your thinking, but GM should make a regular cab short bed version like Mopar does with those "Bee's and Daytona's"
I have an 04 HD 2500 4X4 8.1 and just want something a bit smaller and better mileage.I went from a HD1500 to the HD2500 and you can really tell the weight difference.
The 1500 with the 6.0 looks like its more set up for towing to me than just a sport truck and I think it will be a real nice truck to drive and probaly get around 16 mpg on the high way instead of my 12.5 or so.
The weight difference I would figure will be around 6700 or so for the HD2500 compared to I am guessing around 5,200 for the 1500.
They also have a Silverado performance edition as more of a sport truck also comming out.
Actually Its for the towing group,Its RPO code "NHT" stands for "Enhanced Towing Performance Package" and with the 345 horse 6-liter,4.10 gears,"Ride-Control Suspension" and both an auxilary transmission oil and engine oil coolers I think it'll do a fine job for towing.
MS3DALE could you tell me when this truck could be ordered and maybe how much the option is ?
Thanks for your help.
I also wonder how it would run compared to the hemi.
We are ordering '06's now,but prices are not released yet.
I would hope it would run a lot better then the HEMI! :thumbs: At least it better :thumbs:
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
