Rear Leaf Springs or helper springs
I have a 2000 GMC Yukon Denali, and the rear end sags. It seems to sage worse on the drivers side. I was wondering if this would be fixed by adding Helper Springs, and if so which ones would this community recommend. I have tried searching but don't seem to see much on this item in the forums, or at least that I found.
Any help would be greatly apreciated.
Thanks,
Bryan
Thanks,
Bryan
The rear of my wifes 1999 Burb also saged so I just added a 2" block kit to the rear it it leveled it out. As far as one side more then the other, maybe an additional shim in there with the block.
Thanks,
Bryan
If your springs are not to worn then look into add-a-leafs. They may be the ticket you are looking for.
  • 8 months later...
i have roadmaster active suspension on my truck and it helps out with the sagging under a load. Raised the rear end up about an inch too and doesn't affect the ride all that much.
