He must have been really moving.
Wingnut
I don't speak jibber-jabber, so I can't read it, but the pictures speak for themselves.
This guy must have been flying, I can't even tell what he hit.
Somewhat bloody, but not as bad as the deer pics.
Click here
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
