Code P455
03 silverado 5.3L 69,000 miles.
Check engine light is on. Had code read at the local shop and showed Code P455 (Evaporative System Gross Leak).
Does anyone know what or where I should be checking for a leak?
Don't take this as a smart remark, first thing is to make sure your gas cap is in place and fully tightened. That's by far the most common source of a sudden gross leak. Yes there are codes for small leaks. The shop you went to should have checked that for you and reset the light. Other causes of gross leaks are loose or damaged EVAP plumbing or components. These hoses and pipes connect the fuel tank vapors to charcoal collection canisters then to a valve that regulates their injection into the intake manifold for burning. They usually run with the fuel lines but are larger. Check for a hose damaged underneath, especially if you've been over rugged terrain or ran over something. Check underhood for a loose are torn rubber hose in the system.
Vernon
Vernon
Thanks Vernon. I have checked the gas cap and always make sure it clicks. So far I have not been able to visually spot anything that looks out of wack. This check engine light has come on twice before but went off the next day. It happend maybe a month ago, then a week ago, and now the light has been on steady. I'm going to poke around under the hood again tonight and see if I can spot anything. Hopefully this won't ruin my 4th of july :fume: run to the lake with my boat. The truck seems to be running just fine. Maybe I can get it into the dealer soon. I doubt it though, they are usually backed up pretty good. :cheers:
Guest 007FL
I wouldn't worry about your trip to the lake. I believe SES codes are only about emissions. As long as you can't smell fuel I wouldn't be too concerned. Don't get me wrong. Get it fixed, but don't let it ruin your weekend.
:fume:
I tripped the same code a few months ago. I pulled of the gas cap wiped off the seal with a paper towel. Then cleared the code and off I went. No code since then. I do give the gas cap a couple extra clicks for good measure now. Mechanic told me basically the same as above here. Check all vent hoses running back from the charcoal canister for leaks. Mechanic also said it could be the gas cap itself. I havn't got the code back so I'm assuming it was just a bad seal at the gas cap. I know the cap was tight but it must have had some dirt or something preventing a good seal.
Well, I was poking around under the hood last night and so far I can't seem to find any leaks, cracks, or loose fittings. I've looked over every hose I can see coming into/out of the intake area of the motor. One thing I couldn't find is the charcole canister itself? On previous vehicles I've found it easy. Does anyone know where this thing is or what shape it is? I really need to get a manual but the stores I've looked at never have it for an 03. Time to order online I guess. Next step may be to clean up the gas cap and reset the code. I did check the rubber gasket on the gas cap and it seems ok. Keep the suggestions coming! Oh, and don't worry, I'm no tree hugger! To the lake CEL or not!
Nowadays the charcoal canisters and control valves are mounted very close to the fuel tank. Also on the GM truck it will be above the tank just forward of it. I don't know about your area but here we are under emissions control inspections. any inspection shop can check a gas cap, if not a dealer should be able to.
Vernon
  • 3 weeks later...
On my truck, the purge valve had a rock in it, so it would'nt seal. Thats the valve almost mounted between the bed and cab, that is attached to canister.
    smandy
    smandy
  • Who's Online   3 Members, 0 Anonymous, 526 Guests (See full list)
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
