P0420 Code Issues
RaHCon
June 6-
1999 K1500 5.7l Suburban with 193K on it. Drove DFW to Denver. SES light came on once we got to Denver. Had local dealer read the code and it was "P0420 bank 1".
June 16 -
Cleaned K&N and MAS. Added 1/3 can SeaFoam to 1/4 tank gas. SES was still on.
June 18 -
Started truck this morning, day after order new cats, and SES light is now off.
Cancelled cat order.
June 27 -
Had AutoZone read the codes and it was still showing P0420.
Any ideas? SES is off, but system still showing P0420. Do I need to have this code deleted and see if it comes back? The truck is running fine, but I don't believe it will pass inspection unless this code is gone.
Thanks for any help/suggestions you can give.
Never seen anything but a bad catalytic converter cause that DTC. The light will go off after the PCM has run the test on the converter and it passes three times, but the converter is probably just on the edge of being able to do its job.
Cats are not cheap, so if you want to clear the DTC and see if it comes back, you have nothing to lose, though I suspect you will see it again.
Thanks for the quick response. I guess I was just hoping that the elevation changed had caused the system to get out of wack and now that it's home it would get re sync'ed.
I will get the DTC cleared and see if it comes back. I'll post what the results are.
Thanks again.
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
