Tire Size Computer Correction
Dose any one know the best way to change the on board computer to compensate for a taller tire (265-75-16 vs. stock 245-75-16)?
You do not need to adjust the computer to compensate for that little of a change. I changed my 245's to 265's just like you and was told by the dealer that a computer adjustment is not neccessary because it it not more than a 7% increase in tire size. You shouldn't have any problems, but if you do, the dealer can adjust the computer for you. :banghead:
When your speedo reads 60 mph you will be running 62.4.
reads 80 mph you will be running 83.1
Not a big problem.....
If you do decide to have it corrected, just get a tune from Jesse Bubb. Less than $100 and you get a tune as well.
