Need help air condition problems
Hey Everyone I had the battery disconnected for about a hour tonight, to put on my airaid system i got. My truck has the auto climate control. Well I went for a drive and put the air conditioning on and set it to about 60 degrees and all i get is hot air. Can some one please help.
Bummer.
I disconnected my battery not long ago. After, my a/c sucked bad at anything less than 5mph or so. Stop, and so did the cold. It worked itself out after a day or so.
Is your idle normal or a little rough still ?? Check any fuses ??
Well, I drove to work this morning, and the drivers side is blowing cold air but the passenger side is blowing hot air. Should I wait and see what it does after a day or so? Or should I take it to the dealer so I can get ripped off.
Press and hold the AUTO button to reset it so both sides follow the driver's side until you change the passenger side.
If that doesn't work, disconnect the battery for a while and see if that helps. Maybe something happened while you were connecting it and it might go away if you reset it one more time.
