HIDs... which one: DELTA, SYLVANIA, etc???
Just wondering if there is any consensus out there on the following aftermarket HID replacement kits for a H2 Hummer. I think the H2 takes a 7" diameter headlight.
- Delta HI-LO HID Headlight Kit
- Sylvania Zenarc kit
- Some no-name kit advertised (among other places) on www.predatormotorsports.com).
thanks,
greenhummer
OK. given that nobody is interested enough in replying or this topic is kinda limited for the H2, I thought I'd pass my experience along...
the HID kit sold by www.predatormotorsports.com rocks! The dealer was not that familiar with it before installing it. It has both hi and lo beam HID in addition to having the correct lens which focusses the HID light properly -- i.e. there is a very clear cut line for low beam.
This upgrade is probably the best one you can make to the stock H2. the factory headlights are awful. Of course there's that duramax conversion but I already have a commuting vehicLE.
I've never bought anything from Predator before but was very happy with this purchase. The headlight lens does project out a bit given it's spherical (vs. stock flat) shape. Adding the front guard would ensure nothing could happen to the lights. Even without the guard I'm not that worried.
Note that installation is a snap. The kit comes with connectors that hook up to the factory headlight connectors so no wire cutting is necessary. You mount the ballasts on the plastic (i.e. no grounding) fan shroud and you're done. Might want to adjust the headlights given that with these new ones you can actually piss off other drivers by blinding them.
greenhummer
