Sierra verses Silverado
I just sold my 99' silverado and I'm going to eventully purchase another truck. All my previous trucks have been silverados (88, 89, 90, 99), but I was wondering If I should go with a Sierra this time around.
I would go with a either a 2500 or 3500, long bed, 4x4, ext cab or crew cab, trailering package and leather. I probably won't be able to afford a new truck so I'll be looking at the 2002-2004 models (under 30k miles).
So I'd like some input on the major differences between the Silverado and the Sierra because besides the name I can see any, also it would be helpfull if someone could inform me on what is the major differences between a 2500 and a 2500HD.
Only differnece is the GMC vs Chevy badging and the different noses on the trucks.
Thats it :cheers:
Sierra looks better.
JMO
JMO
:cheers: but I guess I'm partial since I have only owned 2 Chevrolets since I have been buying vehicles (a 1989 Cavalier Z24 and a 2001 Chevrolet ZR2 Blazer). I have owned Pontiacs and GMC's primarily. Actually, the most "loaded" truck I have ridden in recently is a 2002 Chevrolet 1500 SLT which belongs a guy I work with... it has the most options I have ever seen.
ok that what i thought, the difference is mostly cosmetic. Now does anyone know the major differences between the 2500 and the 2500HD?
The GVWR is higher on the 2500HD, and you can chose between the 6.0,the 8.1 big block, or the 6.6 duramax. In the 2500 (non HD)the 6.0 is the only engine option.
When I ordered my GMC earlier this year I was told that it goes for about $500 more than the Chevy with the same trim package. I like the looks of the GMC over the Chevy, but both are great trucks.
The trim packages are slightly differnt, being the GMC's come with one or two things in the mid and high level trim that are options for the same levels of trim on Chevys.
That make sense or I confuse you more? I retyped it several times trying to make it less wordy, but it wasn't working. :cheers:
The dealers are what make it confusing.
When all is said and done both trucks cost about the same.
Example: the chevy LS trim level is supossed to be the same as the GMC SLE. The GMC costs about $400.00 more but the SLE includes fog lights and tinted glass which are additional on the LS.
As far as the 2500 to 2500HD. Besides the engine choices the HD has a taller frame and sits about 2" higher. It also has a full floating rear end.
GMC's use more lockwashers,hence the difference in price... :cheers:
I still get customers in here that swear the GMC's are a totally different truck :D I had one guy not long ago drive both a Chevy and a GMC and he said the GMC rode better,they were both 1/2 ton ext.cab short-bed Z71's so I couldn't figure out why :cheers:
Anymore I just say "yeah" and let them say what they want!
I had worked for GMC as a mechanic. Generally the truck is the same with minor cosmetic differences and small trim differences. You would be suprised how many GMC's came in with a GMC badge on one side and CHEVY on the other. Just depends what day they roll off the assembly line...
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 394 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
