How Latex Gloves Are Made
Scyry
A dentist noticed that his next patient, a little old lady, was
nervous so he decided to tell her a little joke as he put on his
gloves.
"Do you know how they make these gloves?" he asked.
"No, I don't."
Well," he spoofed, "there's a building in Mexico with a big tank of
latex and workers of all hand sizes walk up to the tank, dip in their
hands, let them dry, then peel off the gloves and throw them into
boxes of the right size."
She didn't crack a smile. "Oh, well. I tried," he thought.
But five minutes later, during a delicate portion of the procedure,
she burst out laughing.
"What's so funny?" he asked.
"I was just envisioning how condoms are made!"
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
