Rear diff. broke
I think the spider gears are gone in my 10.5 locking diff. (2500HD) 2wd.
I have alot of play in the diff. and the rear tire locked and dragged today going around a turn (slow) then I heard the gears prang as they jumped teeth.
Replacements are pricey ($685.) plus side gears ($380.) plus labor.
Any one have an alternative other than a salvage yard rear ($1000.00 up)
Is there a detroit locker or something that will fit in the carrier???
Signed "Bummed in CT." :cheers:
Yeah there's a bunch of stuff. I've seen some new Detroit Lockers going on Ebay lately, goto Ebay Motors and search under Car and Truck Parts for "GM 14 bolt".
Also you can google search it and find several vendors of parts and gearing for them.
Here's a link to a very good web page about the Gm 14 Bolt axles with specs and part#s, mods, etc: Pirate 4x4, GM 14 Bolt Tech Page
Speaking of salvage yard rears, you can often find parts rears where you can get the diff for much less than the whole assembly. Use www.car-part.com and when you choose the "part" look under differential. Scroll down to the lower prices and you'll find some parts.
Good Luck,
Vernon
