pcm part number
  • 2 years later...
And man.....this thread is old!!
Thanks a lot. I didn't even notice it was in the HD section until after I had posted. This may not be the greatest place to ask you this but as old as this is, it might as well be a new thread. I have a friend who just bought an '08 Yukon Denali. He wants to order the Escalade mirrors for it but would also like to get the chrome window trim that comes only on the Escalade to complete the look. I'd assume that the two vehicles have the same doors but do you have any idea if the trim would work on the Denali?
Thanks,
Tobias
