reverse camera
:crackup: Hey all, Was wondering if anyone of you have installed the reverse cameras on your trucks. I am planning on getting one when I get my new TNR and was curious to know a good spot to mount the camera.
Also i read somewhere in here the 03 have a gps antenna built into the bigger base for the onstar antennae. I know the 02 had two antennas on top if you had onstar and xm. Guess I was wondering if i could hack into the 03 antennae for my xm radio I plan on adding to the TNR when I get it.
Thanks for any words of wisdom you folks have.
Freewilly
Howdy, here is a write up on my installation.
Reverse camera project
There are kits from snake-eyes, nav-cam and the like that might be a bit simpler than the route I took:
:chevy: Hey all, Was wondering if anyone of you have installed the reverse cameras on your trucks.  I am planning on getting one when I get my new TNR and was curious to know a good spot to mount the camera.
Freewilly
IIRC--the GPS antenna used by the nav unit is separate from that used by Onstar; the nav GPS antenna is mounted underneath the upper portion of the dash. XM antenna is completely separate from Onstar antenna even on '03+--IOW even on the '03+ trucks, there will be two separate antennas on the roof (Onstar on the driver's side, XM on the passenger's side, IIRC).
kay that is what I was beginning to think, I can't remember where I read that the XM and the Onstar were co-located, but I have been looking at newer trucks and they do have both antennas. Thanks for the words.
Just read somewhere today that I think on '06 trucks the XM and Onstar antennas were combined in one unit. It would be nice if this fit in place of our current onstar antenna that way there would be no drilling involved. Might be worth looking into when the '06's come on the lots.
Just an update for you guys. I just installed the GM factory XM system in my truck which currently has the bose 6cdx built in but didn't come with XM. The thing i want to pass is the fact that i had previously bought an after market xm radio which has the little magnetic XM antenna for the roof. Anyway I didn't want to start drilling on my roof to put in the new antennae, and as luck would have it the magnetic little antennae works like a champ with the factory xm setup. Plugged right into the XM module.
So if you are like me and do not want to drill you might consider this as an option. Bet you could get the little magnetic antenna somewhere for less than the price of the GM factory deal.
I have the same question on camera mounting. Most of the installs I've seen pictures of, look OK as far as looking back, but for me it would be more parctical to be able to "see" the back of the truck, bumper, etc. rather than just a rear view. Some people have touched on the subject of depth perception and with no part of the back visible there's no reference. I guess if you just want to look back that's fine but I'd like to be able to keep from smacking something I'm getting close to.
In order to do that, with the angles I've seen, 120-130 degrees, to see an 8 foot wide area, you need to be about 28 inches away from it. So anything any closer than 28 inches that's on the side of the bumper will be off camera if it's mounted in the center bumper area (trailer hitch, license plate frame, etc.)
Seems like the best place is up high looking down like the H2 mount or some Ford, pardon the language, 3rd brake light replacement kits that house a camera. That way you'd be far enough away to see the whole bumper if looking down and could see things close before they hit. On my Yukon the brake light area is too far forward and you can't look down from that point. The other problem I have is wiring from that area. I thought about maybe hiding one with those air deflectors but they have a cut out in the area of the brake light so you can see it. I'm thinking about buying one of those $50 or less 120 degree cameras and playing with locations. What might be nice is if someone would come up with an image combiner or split screen unit to use 2 cameras looking different ways then you could see down both sides of the bumper from the center. Then again, this may not be what most folks are using a backup camera for cause there don't seem to be too many products out there right now to do what I'd like.
mctaf--yep, you'd need to mount it on something like a rear-wing spoiler or rear-air deflector like you mentioned if you want the camera angle you're referring to.
    • Idler Pulley… from what I understand GM and Chevy trucks no longer have an idler pulley.. they stretch belts for both belts… I had mine replaced by my local mechanic last year on my Chevy Silverado 5.3 z71 LT.   They have discontinued using them on 2019 through 2026 as of a Google search.
    • Good morning! I have a whirring sound coming from the engine or transmission area when driving w/o towing when I accelerate at 1100 rpm’s. That’s how it started. Yesterday it was more obvious while towing a U-Haul even when not accelerating at 70 mph. I could see where it may have been possibly shifting gears due to a slight grade and the intermittent rpm changes as the transmission was possibly lowering the gear down. It was making the sound multiple times but it is not constant. I replaced the serpentine belt and idler pulley but no change. It only does it when I’m driving. No noise accelerating while in park. Just started @ 53,000 miles. It’s not always there though. Unfortunately, I feel it may be transmission related. Any thoughts or knowledge about the 2022 tranny that anyone can share. I have 2500 miles left on my p-train warranty. Thanks to all for any help!
    • RAIN. It's dumping buckets. We needed it. What a welcome change...sitting here listening to it pour with my office window open.   Ok, not too much. It's not even September yet, we're not finished with summer yet....
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
